How can I edit this STL file?
david_misc
Member Posts: 5 ✭
I downloaded an STL file from https://grabcad.com/library/tardis-metropolitan-police-box-mk2-1
But I can't see how to edit it e.g. draw on it.
I seem to have managed to import it to an extent
But if I try to open it e.g. open workspace,
It just shows
And I can't see how to open it so as to edit it, to draw on it etc.
Thanks
It just shows
Thanks
In the other tab you will see the Part Studio that contains the STL. Keep in mind, you can not modify STL data within Onshape. You can only use it to reference to.
Twitter: @bradleysauln
the tabs I see are just CAD imports and Met Police. I can't see any others there. And I think i'm on the met police tab.. and when l click the CAD imports tab then nothing happens.
what file format does onshape use? like what file format can / does it save and edit with?
also, is there any file format that onshape uses that is compatible with almost any 3d printer?
thanks
