Rotate a MC along two axes
Henk_de_Vlaam
Member, Developers Posts: 265 ✭✭✭
Since OS 1.93 (20190301) it is possible to use an implicite Mate Connector as sketch plane. In https://cad.onshape.com/documents/715412c9c1163434269387b8/w/ef89d03cbf95f0bdc274f57a/e/df70441e6400d5047759127f I needed to tilt that sketch plane in two directions. However, as far as I know, a Mate Connector can only be rotated in one direction. So, to get the two angles I used some extra features (see comment in example). Before I make an IR for the rotation of a MC along 2 axes instead of one: is this already possible and did I missed this?
Yep, I think that will do the job.
You are talking about a Custom Feature isn't it? I cannot find that feature in Public. Does that mean that you have to create it?
Thank you very much. That’s what I need. What a luxury when one masters Feature Script
I used/tried V2 already instead of all the extra features and it works fine. See the feature folder CoG Point + MMC in https://cad.onshape.com/documents/715412c9c1163434269387b8/w/ef89d03cbf95f0bdc274f57a/e/df70441e6400d5047759127f
About the ‘conditional input type selection’: Do you mean that the array values are not usable as a configuration variable? I tried that with no success.
That was the trick, see the example above. Thank you,
