Extruding up to surface with hidden area
gauthier_östervall
Member Posts: 99 ✭✭
This is a minimal example: https://cad.onshape.com/documents/f2056bc8a4f21f6dc05c0aaa/w/db5173e0d0b77e5474e5fa42/e/bfaac868460e035bc6c0abf4
I have a surface with acute angles, which I project to a plane in order to extrude from the plane to the surface. The acute angle of the surface make the extrude fail, which I can understand. How would you go about making this work? Extrude all that is see-able from the plane in several steps, then fill in the gap? Isn't there a more elegant solution?
Here is where I extrude. The volume under the acute part of the surface, where there are three faces stacking up over the sketch, seems to be where the extrude fails (see Origin):
steve_shubin
Member Posts: 1,118 ✭✭✭✭
@gauthier_östervall
https://cad.onshape.com/documents/24fcf2bbbaebe74e0195dc63/w/d7ee1cbaeadcaa16c0c4f6a9/e/833f8267778ddcb3089b1e2b
Maybe this will work for you
You might want to look at both parts studios
5
Owen.
If you are trying to "add" these together, it will create non-manifold geometry (a solid cannot have coincident edges or vertices with zero volume).
The image shows the extrude that works, though. It stops working when I add the middle sketch face to the extrude (expecting a manifold volume). Sorry if I was unclear.
In this very case it doesn't cut it entirely since the upper side of the surface doesn't expand to split the volume, but that might be enough for my real project.
I would expect the extrude to work as is, and go to the bottom of the surface.
