Query external bodies during in context edit of part from assembly.
Hi.
I am wondering if there is a query that will find bodies while editing in context of an assembly.
Basically, I want to import all assembly components into a part studio to “Shrink Wrap” the model to be shared with internals hidden.
All I am missing is the ability to Query All in context bodies. perhaps qAllInContextBodies 😊!
Thanks, let me know if there is something that may work, or a hint if it’s something in process.
Tdat being said, you may need to invoke in-context manually and update manually
Then the beging of your fs could query all bodies and transform copy inplace. Then make a composite part. All in the FS.
That sound right?
I figured this was the response I would get, manually doing things is not efficient. This is why we automate stuff correct?
the bodies exist in the interface, but grayed out as they actually only exist in the assembly portion.
I already have the featurescript written that will copy the bodies, opPattern them using identityTransform.
I hope in the future, onshape exposes access to in-context parts. I Suppose the API is capable of doing this, but featurescript is so much easier and faster to work with.
thanks for your reply.
