Text Videos
mike_72
Member Posts: 4 ✭✭
I was looking for instructional videos on how to use text in Part Studio to create embossed or engraved items. I found the following improvments link but the videos are missing.
https://forum.onshape.com/discussion/1209/improvements-to-onshape-july-17-2015
Can these links e recovered please?
Mike
Mike
john_mcclary
Member, Developers Posts: 4,035 PRO
All you have to do is create a sketch then click the text feature
Should look like the letter 'A'
Then select the area 'roughly' that you want to place the text, it will be like drawing a rectangle.
Then the text box will pop up.
From there you can format the text and type it in.
Then confirm the box, and resize/and move the text where you want.
then extrude your sketch.
More info here:
https://cad.onshape.com/help/Content/text-sketch.htm?Highlight=Text
6
More info here:
