Sketch could not be solved.
john_lombardojohn_lombardo Member Posts: 20 EDU
Sketch (Outline)  could not be solved and did not regenerate properly.
There are problems with other sketches but fixing Outline might help them also (maybe.)
https://cad.onshape.com/documents/e914ccef58bb77ae389eb54a/w/ed77bdb8b82c349928e441d6/e/06f773065cb89eb58aad139a
    Looks like you've got dimensions fighting each other.  Eg on the left edge you have a dimension, and on the right side you have 3 dimensions making up the same edge but the maths is off.
    Here:- clicky I've changed two of the dimensions to "Driven" meaning they're just measuring the result, not forcing the sketch to be a dimension it can't be.
    A general rule of thumb is if you have anything red then stop and fix that before digging a deeper hole with downstream features.  Some of the other failed features are a bit more helpful in the error reporting, you'll see stuff like "missing part" in the merge scope for example.
    Hope that helps, shout if it doesn't.
    Owen.
  • john_lombardojohn_lombardo Member Posts: 20 EDU
    Thank you, that works. Useful to know what "driven" means.
    Now the drawing is not all black. What's the best approach for that?
  • audria_alamaudria_alam Member Posts: 2
    For my sketch it says it cant be solved and also I cant edit anything
