How do I convert a picture/document into a sketch?
I was wondering when I import a picture how to change it into a sketch
  • mahirmahir Member, Developers Posts: 1,319 ✭✭✭✭✭
    edited January 2020
    There is no automatic method in Onshape, barring an add-on that I'm not aware of, to automatically convert a picture to a sketch. You can insert a picture into a sketch and manually draw sketch geometry over it. See my example below.
    https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/e5bdf34d7618a0c8cd011f19
  • brian_jordanbrian_jordan Member, Developers Posts: 144 ✭✭✭
    Similar to @mahir's example above this document has coasters and cutters designed using the imported jpeg shown in tab transformerface-2.jpg
    https://cad.onshape.com/documents/24ebbb4af61fa4df9922bdc7/w/4c49a71723e8bf4c8446e57f/e/309093e0c22fd4eaaa5a8371
  • wayne_sauderwayne_sauder Member, csevp Posts: 628 PRO
    I don't have much experience but this site might be able to convert it before you import it if that would work. https://www.scan2cad.com/
    Also if you are getting your picture from some kind of professional source, you may be able to get it as DXF or DWG, which will come into the sketch as sketch entities.
  • david_desaulniersdavid_desaulniers Member Posts: 1
    I can import and get a picture in a new tab but cannot get it into my sketch, Nothing shows in pane when I open Insert in sketch mode.
    mmm -   Insert Image should work fine once you have Imported a picture file.  Best to make a seperate sketch for just your image.  Then make sure to Draw image rectangle after choosing image.
    See help on Insert Image here.
    Another tip is to make your original image to the boundaries of the part.  Then sizing & positioning it during insert is easier.
    www.accuratepattern.com
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,001 PRO
    What is the file type of the picture?
  • david_urufudavid_urufu Member Posts: 3 ✭✭
    I know this is an old thread, but i was in the same situation and trying to make a sketch just using splines, dots, rectangles, lines etc. is very, very unacurate and tedious way how to do this. Use some online picture-to-dxf converter (like https://convertio.co/jpg-dxf/) and You're done in a few seconds - the quality of converted file depends on the quality of the picture. Then import the .dxf file into the sketch.
    Yep, In the years since this thread I would typically use Inkscape to autotrace and export a DXF. I'm sure there are plenty of similar options, but I usually have Inkscape installed anyway to do some light vector art editing.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,472 PRO
    I have tried some online tools in the past and found Inkscape did a much better job (and gives you some control to adjust the result)
  • yves_bardoutyves_bardout Member Posts: 2
    I tried many things to use geometry from a logo jpeg, that I converted nicely to svg, and also to dxf, as many comments said it was the only way. InsideOnshape, nzw docment, new sketch, and import tool :
    Indeed svg open as an raster image in new tab, import dxf open a new tab - one layer with several splines. Must get ri
    I tried the copy/paste, this use tool, and no way to get the splines inside sketch, seems a
