Interference or tesselation issue?
tony_459
Member Posts: 206 ✭✭✭
I noticed a part sticking out of another and thought I had interference... but when I used the interference tool, the results said no interference. A section view shows the red we've come to expect from interference, so I'm wondering: could this "interference" be the result of low tessellation? Tesselation is set to Auto, meaning that Onshape adjusts it as necessary to keep up performance (is my understanding). Low tesselation will cause vertices to seem misaligned when in fact they are not (as smooth splines and arcs are rendered as rough polylines, say), so I'm wondering if the interference red I see in cross section is just another effect of low tesselation. Thanks!!!
If you want further assurance, you could manually set the tessellation quality of the relevant parts to "Very fine" in the appearance dialog. This will add some expense to the rendering, but it will give you a more accurate representation of the surfaces. This will likely reduce/remove the interference highlighted by the section view. Once you're satisfied, I recommend setting the tessellation quality back to "Auto" to help maintain performance.
