Injection mold design
Hi,
I'm injection mold designer. I'm working on Solidworks, but I'd like to try Onshape - I like the idea of cloud. Now I have WD My Cloud network drive, it allows me to access files from anywhere, but it's working really bad. It crashes and suspend all the time, so I don't have access to my files when I'm not in the office. Additionally, when I'm out of office I have to download the file and then upload it. It's really annoying, but it's better than saving files on external drives. In short, I need cloud based software. I need it especially when I'm at CNC workshop and I have to talk with guys about mold details. Unfortunately Onshape capabilities are bit limited, so I can't design any mold in this app. Of course, you can make simple mold there, but I need professional tool like Solidworks.
I think all injection mold designers need these tools (maybe I forgot something):
- draft analysis,
- neutral line creator,
- parting surfaces creator,
- shut-off surfaces creator,
- automatic mold creator (core and cavity only),
- surface editor, which helps you when automatic mold creator doesn't work and you have to manually make core and cavity.
All these tools are available in Solidworks Standard.
Will you develop this application in the direction of injection molds?
Best regards,
Maciek
Best regards,
Maciek
and ... the more ways we find to use it for paid work, the quicker it will catch up !
@philip_thomas put it very well. Keep learning and pushing and using as much as you can. Give input when you can. Be sociable here on the forums. This platform is where the power lies, Full cloud CAD. And keep in mind for the short term that we are comparing Onshape to CAD systems that have been in development for 20 years or more now. It's remarkable how fast Onshape has gotten to this point. The next 5 years are going to be really interesting. You'll want to make sure you keep your hand to the till here.
To solve your first problem with that crappy network drive (I tried something similar in the past, it was crappy too) you can import native solid works files into Onshape and view them in CNC-shop. You can also modify with direct tools or just make comments for fixing back home.
With simple molds doable in Onshape I suggest you tip your shop about the software and save time & gasoline by working together with them in same workspace straight from your office.
You can always download your models back to solid works (without history) if Onshape ends up being short on some advanced modeling task.
I wanted to buy MS Surface Pro 3 to work with Onshape, but it doesn't make sense for me if I can't do my job on it. I will wait for these mold tools and also for cheaper PC tablets. So there is nothing but wait and learn Onshape in the meantime
