Can we carve, emboss on curved surface ( not cylindrical... , but a manually constructed surface )
uniz_agusto
Member Posts: 5 EDU
Can we carve, emboss, draw or extrude on a curved surface ( not cylindrical surface ... , but a manually constructed surface ) ?
Thanks.
Thanks.
https://cad.onshape.com/documents/9f26ac1fc159944e425ee7b6/v/913cabf2116094a3134756f1/e/429c04fd031f38814365d2d9
Or you could create a surface with the "Offset Surface" feature then extrude up to that.
Cheers,
You're welcome, glad you got something out of it.
Owen.
1) Wrap a sketch on a cylindrical face
2) Project a sketch onto any analytical surface (same as extrude up to face)
Both are supported by Onshape today.
The third scenario is very 'inexact' - 'wrapping' a sketch onto an analytical surface. Imagine the sketch was on a piece of paper.
There is no way to get the paper to lay flat on the surface without it wrinkling. Any solution therefore is an approximation and we do not support this (because we like things to be exact
If there is a specific Engineering need, lets talk about what it would take to address
3a - the surface has curvature (not necessarily constant) in one plane (extrude a sin wave as a surface, for example)
3b - the surface has curvature (not necessarily constant) in more than one plane (a saddle shape or sphere, for example)
Wouldn't 3a have exact solutions?
I don't have an immediate need for these, but could definitely see the value in it.
The 3a scenario is fairly easy.
As an example, you can convert an 'extruded' face to sheet metal and it will work fine
(Internally, it is classified as GeometryType.EXTRUDED)
Additionally, there are 'cone' faces, which also have an exact solution.
However, Onshape's sheet metal tool doesn't like them
Internally, sheet metal flat view and wrap feature are using the same code.
I don't see an IR for it, so maybe someone can make one
