Is 'Create Selection' inactive on In-context geometry?
bruce_williams
Member, Developers Posts: 842 EDU
I want to confirm before I put in an IR.
I am looking for this when designing fixtures using huge import model as a 'Master Model'. I want to avoid copying the part into part studio.
www.accuratepattern.com
lana
Onshape Employees Posts: 748
That is correct. Create Selection does not work for context selections. As a work-around you can make a copy of context body which would become local for that part studio context. Then you can use create selection. Please file the IR.
1
The selection in Context mode is really hard to use. You also can't use the "~" (select other), I don't think.
I added the 'select other' to the IR. Thanks for pointing that out; I had noticed that too and it will be very helpful to get both selection tools. Please vote on the Improvement Request here.
