Turning one part into a bunch of smaller parts for 3d printing
jbmjbm Member Posts: 1
I've designed a stand for my laptop but it's to big for my 3d printer, I'm wanting to cut it into smaller parts with interlocking joint points but i can't work out how to cut up the original part into smaller parts along the joining points I want to make. The only idea I've had so far involves making a bunch of cuts using the "split" tool.
this is the part as it currently looks:
this is the cut I want to make:
  • rune_thorsen229rune_thorsen229 Member Posts: 182 EDU
    edited March 2020
    HI @jack_mavor. It looks like a nice design. We work with 3D printing as well. If you make a clean cut of your parts to let them fit your printer, how do you assemble them?
    I found that there is a catch on positioning if you are interested: https://forum.onshape.com/discussion/comment/60673/#Comment_60673
  • robert_scott_jr_robert_scott_jr_ Member Posts: 604 ✭✭✭
    Hello jack_mavor. Based on past experience on fitting 3D printed parts together, I would not print the entire piece(s) as is after the split. I suggest doing two other splits before and after the connection split to render smaller 'test' pieces to print. After printing the 'test' pieces and fitting them together, you may find the need to take .004-.008" of the faces of one of the pieces to acquire the fit that pleases you. That may avoid wasted many hours printing pieces that don't fit. - Scotty
