Positioning parts on Curved Patterns
I want to position non-symmetrical shaped clip pieces along a curved path. My problem is how to position the starting piece, define the spacing and number of repeats.
In my test example I created a simple box at the centre of my curve and repeated it along a curved path. Central positioning makes it straightforward to achieve initial alignment. As you can see the pattern is extended for the full length of the path, so I need to start at one end not the middle. If I start at the end what is the best way of achieving initial alignment (on the curve) and how do I prevent the last piece from over-running the end as I find that the pattern tends to exceed the curve length by one unit.
Or is there a much better way altogether?
My thanks.
mahir Member, Developers Posts: 1,316 ✭✭✭✭✭
In this particular example, your curve is just an arc. So you'd be better off using a circular pattern. The spacing can be controlled directly, or by setting the total angle and number of instances.
https://cad.onshape.com/documents/902bd73c14b958f73261b56b/w/61d56750bb20e1a2d2282f61/e/c8491bed2e2457268ee8bd85
5
