[NEW] Keyway Groove FeatureScript
TimRiceTimRice Member, Moderator, Onshape Employees Posts: 315
With our recent release of Keys to standard content I created a Keyway groove custom feature to automatically cut the appropriate size grooves for a given shaft or hub diameter. ANSI and DIN included!
Add to your toolbar:
https://cad.onshape.com/documents/d003c1d368860b9ec4395d78/v/436edc447670f4091e6aedb0/e/c1c903f1ce2aee7e8e2c92dd
Onshape, Inc.
    Cool, Nice job
    Could you add a couple of things eventually?
    add the radius' when blind
    an option to cut centered on the mate connector
    Opposite direction for depth
    Depth should probably be named Length right?
    Thanks
