How to create a 3D model from orthogonal projection (Orthographic projection) ?
rune_thorsen229
Member Posts: 179 ✭✭
What is recommended workflow starting from an orthographic projection to 3D representation.
Example :https://civilseek.com/wp-content/uploads/2018/12/orthographic-projection-drawing.jp
I import the JPG in a sketch, lets call it 'projectionsketch' . Then I outline the TOP FRONT AND RIGHT side.
Is it then possible to project parts of this sketch onto a TOP, FRONT and RIGHT sketch?
Then I guess one should extrude each of the 3 sketches and the intersection should be the model right?
What I really want is to have a parametric model driven by the dimensions on the 'projectionsketch' . For example I would like to make the front a bit longer, so I do it in 'projectionsketch' and everything gets modified automatically.
Sorry if this is a very basic question but I cant find good guides on the topic.
Optionsrune_thorsen229 Member Posts: 179 ✭✭rune_thorsen229 said:PS: I found this tutorial that shows how to do it but it's not onshape :https://www.youtube.com/watch?v=ZFSV47I7SBg
To summarize: It's not possible to use the "AutoCAD 2D to 3D Conversion Trick" by 'turning' sketches '90degrees up' (while keeping original references), though it should be programatically simple.
In my case I have a 'client' that has made a drawing and would like to turn it into a model and I found it baffling that it was so difficult when other CAD has this possibility:;https://www.youtube.com/watch?v=ZFSV47I7SBg
The actual questions are whether it's worth the effort and whether the result would be accurate. As Neil said it's almost certainly quicker, easier and more accurate to use other methods.
From :https://forum.onshape.com/discussion/comment/60481#Comment_60481
Case story for 'raising' sketches to orthogonal projections.
A collegue propose to make this device that has been sketched as they teach you in school
https://cad.onshape.com/documents/7047b5746d757ac5dd0d5bae/w/7a31455153d74d67bf3400db/e/b4188f5b5481fb09e1f87972
I thought it would be simple to make a mockup, make it parametric, 3D print a small demo and then scale to full size.
As Onshape 'potentially' could be very easy if it allowed the workflow described here:https://forum.onshape.com/discussion/comment/60295/#Comment_60295
and it shouldn't have taken much time. I notice that my students using Onshape keeps making their designs non-parametric (Im more a programmer than a designer so I don't like inserting konstants) and run into problems when needing to change diameters on the fly.
Hope that clarifies the workflow I hoped could be achieved in Onshape.
