Loft new solid gives a surface
I don't know if it's because of my start/end profile conditions, but my loft solid gives a surface.
What is going on? The other similar loft (currently suppressed) works fine. Here is the project: https://cad.onshape.com/documents/4bf7f623ce4a039e24576ef7/w/1e00e61cde1b8df1802bb9bf/e/5445ea5ca63ed7637f996635
Edit: yes, End condition Tangent to profile turns the solid into a surface. But I want the End condition!
I didn’t take time to go through your document to see why your loft wouldn’t give you a part. This looked like it could be quite involved. Probably above my skill. But, I did use the Enclose tool to quickly turn 4 entities into one part. Don’t know if that’ll make you happy or not. But for what it’s worth, here is a GIF
https://cad.onshape.com/documents/6595739ff81c12d3c691a07f/w/621fd0bdcffe9501cf003785/e/43f395f8db85295298bffff6
A solution is to have the same amount of points on each profile of the loft — which is a good rule of thumb when making profiles for lofts
To get the Tangent to Profile, End Profile Condition to work on the loft, the End Magnitude was set to .9
It may not be a loft you were looking for because of the number and depth of the creases in the part. Getting rid of those creases will take at least one and maybe more intermediate sketches (profiles) and a number of guides. But it is possible to loft between two profiles of the shape you had, use the end profile condition you called for, and come up with a part without using a workaround
For what it’s worth, if you set the end condition to none, you end up with a shape that is fairly smooth
I agree that Loft maybe wasn't what I was looking for, but I don't know what else. Guides and Fills?
The solution involved not only changing the magnitude to .9, but also redrawing one or both sketches
As to eliminating or softening the creases, I believe it would involve making at least one or two INTERMEDIATE sketches and possibly some guides
