Cumulative Measure
I was almost certain that Onshape already had the capability to report the combined length of a chain of sketch entities (eg lines, arcs - not sure if it extended to chains including splines) once they were selected. In my recollection the readout at bottom right showed the aggregated length.
I can't get that to work for me, now that I need it to work out the length of material I need for a series of complex bent pipes. Was I imagining it?
lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,011
@andrew_troup I don't think that was ever the case. We do measure length on single entities like lines and splines. We do have an open improvement I can add you to.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.6
Please add me in; this would be a time and error saver, for sure.
