Named view is getting cropped in drawing
Pascoe_Design
Member Posts: 18 PRO
It looks like the issue is with the shaded view, not the view geometry. I'm guessing that if you disable the shaded view, you will see that all of the view geometry is fitting properly within the bounding box.
Can you please create a support ticket from the `?` menu?
Best,
Mike
Thanks
Liz
