Place where I can find some more descriptive documentation on EntityInferenceType
C_JustinC_Justin Member Posts: 16
Hi there,
Just want to check where can I find some descriptions for EntityInferenceType enums? It seems the documentation column for this type is empty in the feature script doc.
Thanks!
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,419
    See https://cad.onshape.com/FsDoc/library.html#mateConnector-Context-Id-map - these are the positions where a mate connector appears when you drag your mouse over geometry.
    edited February 2020
    @C_Justin
    I will put in a ticket internally to document this enum.  Thanks for pointing it out.
    Once the descriptions are generated I will post them here as well so you don't have to wait for the push.
    @C_Justin
    Still working on this, but I realized that this Enum is only used in the `mateConnector` feature.  When using FeatureScript, it would be better to make a call directly to `opMateConnector` (the underlying operation which adds mate connectors to the Part Studio) rather than the `mateConnector` feature, which is the code that is called when the user clicks on the "Mate connector" button in the UI. (i.e. it is a Feature, in the same sense that your custom feature is a Feature)
    https://cad.onshape.com/FsDoc/library.html#opMateConnector-Context-Id-map
    This is a good general rule when programming in FeatureScript.  It is easier and faster to call `opExtrude` than `extrude`, `opRevolve` than `revolve`, `opSweep` than `sweep`, etc.
    @C_Justin
    Finished this up, it will be available in an upcoming release.  In the meantime, here is the documentation for those fields (the undocumented ones are not implemented for FeatureScript, and will always fail)
