Error when adding chamfer or fillet at the start of a threaded hole
Cedric_Eveleigh
Member, OS Professional, csevp Posts: 61 PRO
does the chamfer work if you roll back to it? (basically, is the chamfer failing or is the thread failing?)
if not, try that as an experiment. see if that helps
I just tried sweeping the thread as a new part and then boolean subtracting it, and there was still an error.
