<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
Error when adding chamfer or fillet at the start of a threaded hole
Cedric_Eveleigh
Cedric_Eveleigh Member, OS Professional, csevp Posts: 74 PRO
Has anyone else experienced an error when attempting to add a chamfer or fillet at the start of a threaded hole? (the thread being subtractively added, and the chamfer or fillet being added before sweeping the thread)
  • john_mcclary
    john_mcclary Member, Developers Posts: 4,110 PRO
    is your chamfer before the sketch that defines the helix also? that could cause a relation issue.
    does the chamfer work if you roll back to it? (basically, is the chamfer failing or is the thread failing?)
  • Cedric_Eveleigh
    edited March 2020
    The helix is not defined by a sketch - it's defined by the cylindrical surface of the hole. The chamfer does work if I roll back to cancel the thread sweep. Both the chamfer and the thread work alone. The chamfer appears to be causing the thread sweep to fail.
  • john_mcclary
    You say the sweep is subtractivly added, I assume you mean you are sweeping a new part, then boolean subtracting it right?
    if not, try that as an experiment. see if that helps
  • Cedric_Eveleigh
    By subtractively added, I mean that the sweep is in "Remove" mode, rather than "Add" mode in the sweep dialog.
    I just tried sweeping the thread as a new part and then boolean subtracting it, and there was still an error.
  • Cedric_Eveleigh
    If I slightly increase the size of the hole ("Hole trim" in the screenshot below) after creating the helix and before subtractively sweeping the thread, the sweep does not fail because of a chamfer created before the sweep. This work around is fine for me but it still seems like the issue should not occur.
