What is the actual URL of a public project ?
matthieu_2
Member Posts: 4 ✭
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
@billy You will notice the url is broken up by document id, workspace and element (tab). The link is still governed by your share permissions and currently PUBLIC is all Onshape only. We are working on a way to share with people with a link and/or embeddable option. Stay tuned for that...Lou Gallo
Sr. Director of Product Definition. UX and Support5
It has certainly worked for me
https://cad.onshape.com/documents/a56dd4152b7e4ccf91212d7b/w/42364f500bd242359c0b5ce4/e/fc516cd7f7c14abebdf846c0
But that's not everything. When you give this to your friend and he enters it into a browser, the server looks to see if he's eligible. Just because you can see it doesn't mean he'll see it. OS sets cookies on your computer and knows who you are. The cookies time out or cancel when you close the tab. If your friend doesn't have a cookie set, then he can't see it. Public means all OS registered people not any one in the world.
If no OS cookies, then OS should ask user to register.
If OS user cookie set, then OS should ask the user to login.
If OS session is set (by a cookie), then OS will display the url and contents.
Maybe I'm little wrong, but I'm mostly right.
Now if your friend is working through a proxy server or his IT guy is blocking this url. It won't work.
I think Andrew says it best, if you want to invite some one to OS, share your document with them. It's the fastest way to get someone involved.
Until now, I copy the url address bar but people with OS account told me it was not working. Maybe it was an error from their side.
Thanks for you answer I will keep up to date if I have still trouble
Please remember that you can't use RMB on document list for copying public link, you need to actually open model to get correct link in your address bar.
Link from document list:
https://cad.onshape.com/documents/d29ff8e74a0f49809e533f48/w/48fedb2064cc4f30a27ee6e8
Link after opened model:
https://cad.onshape.com/documents/d29ff8e74a0f49809e533f48/w/48fedb2064cc4f30a27ee6e8/e/d2225c9e50db4df088eb880d
Sometimes it would be nice to copy public link from document list but it is also good that you a forced to see what you are linking to..
EDIT: Inaccurate / old information striked after further testing..
I came back to test if things are changed and now it seems that both are working (at least for me, but don't know if it's because of cookies/cache)
Did you change something on this matter? I remember clearly that links didn't work if took with RMB (copy link address) from Document list and paste into forum.
