3D Sketching in-context (wire rope)
VanJrVanJr Member Posts: 9
edited September 2018 in Drawings
I am evaluating Onshape as a possible replacement for Solidworks - for which we have been using for 20 years.
I am trying to create a wire rope routing around two sheaves similar to this screen shot (done in SW):
Here is what I have in OnShape (simplified version in an assembly):
In Solidworks, I create an empty part, insert it into the assembly, edit the part in-context of the assembly, make several sketches to define the path, a sketch to define the profile, and perform a sweep. In Solidworks, the features (planes, points, sketches, etc) of my parts/assemblies are made available in-context for use to define coincidence points for the path. When I attempt to do an in-context edit in Onshape, none of the features of my parts/assemblies are made available to reference.
How does one accomplish this in Onshape? Anyone have a video link?
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,241
    On one hand, Onshape doesn't currently have 3D sketching functionality, so replicating the workflow exactly is not possible (without manually constructing a bunch of 2D sketches).
    On the other hand, this looks like a great opportunity for a custom feature, which if done right, can lead to a better workflow (e.g., just select the pulleys in sequence).  I might try to give it a shot in the next few days, but someone here might beat me to it :smile:.  One question I have is how you represent the endpoints -- do you have anchors or is there a "down" direction or are these closed loops?  Perhaps a more complete series of screen shots of what you want the full end result to look like would help.
  • VanJrVanJr Member Posts: 9
    Well, I sorta figured it out.
    First, Onshape cannot insert a blank "part" (or file) into an assembly - even if I want to mate origin to origin. This is a limitation.
    Second, I had to create a separate parts studio for the wire rope. I made a profile (circle) and then extruded it symmetrically 1mm. Now I am able to add it to the assembly and mate it to a mate connector I added to the sheave to represent the wire rope tread (the four mate connectors shown) . Then I edited the wire rope in-context and added individual segments based on their plane (Top and Right in this case). However, all the segments are treated as individual "parts". That's confusing.
    Problem: In-Context constraints do not seem to work well. If I adjust the distance between the two sheaves (say 100mm) the wire rope does not rebuild and adjust (lengthen) the top segment as show here:
    The tangent-circle-center is defined concentric with the sheave bearing but this constraint is not maintained. This is disappointing. I can't figure out how to solve this problem.
    For reference, here is what we design and we need Onshape to ultimately do:
    In Solidworks, this assembly is completely flexible. We can move the cylinder, which will move the block, which will raise/lower the platform, and the wire ropes will also adjust accordingly.
     So here's something to help the process along: https://cad.onshape.com/documents/95c4e687bb85aaf89a575e5f/v/fe9fdcc43389bdccc94c65c1/e/99e3ac17fa175e722243e94e
    The structure is that, like in your last post, you make a bunch of mate connectors where the rope should go, but you also mate identical circular profiles to those mate connectors (you can insert a sketched disk from a part studio into an assembly).  Then you create a single rope part in context using the custom feature I just wrote (it's reusable).  You can then move the profiles, pulleys, etc. -- the context won't automatically update, but it will with a single right-click on the rope and go to "update context".  I'm running off right now but let me know if I can clarify any part of this.
  • Hans_Ole_LeirvikHans_Ole_Leirvik Member Posts: 82 PRO
    Hi guys, this what I have been waiting for in OnShape.
    I really hope the Custom Feature (FeatureScript ??)  becomes a reality.
    I have worked with similar wire designs in Soildworks for many years and I have experienced lots of problems.
    As you can see in the image below we have many sheaves. The wire comes from a sheave, entres the next sheave tangentially and exits in the direction of the next sheve, entering again tangentially.
    If one sheave is moved all sheaves will move, because the angle of wire in and out changes a little.
    I use 3D sketch in an in-context part to achive this.  If OnShape if can do this in a simpler way it would be fantastic :)
    Some more photos here.
    Sometimes we need to plan a lift and rigging operation in detail.
    When using many chain hoist we come into a similar design situation. If you pull on one hoist, all the others are moving.
    Here another situation, many ropes, slings and steel wires in any direction, many related to each other ...
    Rope Access IRATA Services
    Source: www.conbit.eu
  • nicolas_duhamelnicolas_duhamel Member Posts: 7 ✭✭
    edited March 2020
    Hi there. I'm willign to accomplish almost the same thing. Although the method proposed by ilya_baran works when rope angles are fixed, I'm looking for a method in the case of varying rope angle. As Hans explained in his last post, when the system has non linearly moving parts, the rope that goes tangently to the pulley will change angle, and I can't achieve that.
    As this topic was written 2 years ago, I'm hoping there is now a way (or workaround) to do this ? Maybe someone has written a script ?
    Any feedback appreciated, thanks !
