how do i share with my professor that i have completed a tutorial?
conor_caseyconor_casey Member Posts: 2
  • KatieHuffmanKatieHuffman Member, Onshape Employees, Developers Posts: 194 image
    @conor_casey this depends how the professor would like you to do this. If you are referring to a particular exercise, you may share your document with the professor. We also issue completion certificates upon completing certain courses and pathways. The professor may want you to show your certificate to indicate you completed the course or pathway. I would ask your professor what you should turn in to show you have completed the assignment.
