Document description
rune_thorsen229rune_thorsen229 Member Posts: 182 EDU
I know now that I can use descriptions and comments but I think you could do better.
Use this empty space
to allow for the designer to put a few words describing the current tab (assembly or part)
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    @rune_thorsen229 That area of the UI is the document, not the tab so it would be a bit confusing to have tab specific data on the header. What about in the hover behavior?  Today we show the preview.. maybe other data could be present.  Otherwise an option to show the tab properties in a right side panel might also open up the visibility of metada.
