How to Model "Diamond Plate" Pattern
matthew_stacy
Member Posts: 489 PRO
in General
Has anyone in the Onshape community had success modeling "diamond plate" (textured aluminum or steel for tool boxes, floor surfaces, etc.)? I'd love to hear how you approached this.
https://cad.onshape.com/documents/960d506f8f974586c1801821
In general we do not recommend highly detailed patterns like this as it is often not necessary. If you do absolutely need a pattern you can use a Split face feature to split the initial two bumps and then use a Face linear pattern to pattern the rest.
Onshape, Inc.
I found this texture custom feature which does this easily: https://forum.onshape.com/discussion/16576/texture-new-custom-feature
