Drawing with Parts Studio Configurations
kent_hendersonkent_henderson Member Posts: 71 PRO
In my parts studio called Tote Goat Guard Set I will have approximately 80 different configurations. This was amazingly easy to do. (I know I didn't need to use variables but by naming as such it's easier to enter from my spreadsheet). Here is my question. I have made a drawing of the first configuration AL190SN. Is there an easy way to do a drawing for the other configurations?
https://cad.onshape.com/documents/1f32343c9e7a2a9154d66504/w/df137f47a8698bbcfacf8cf6/e/bcaa9c09cf2297e23c8ca5e3
  • John_P_DesiletsJohn_P_Desilets Onshape Employees, csevp Posts: 273 image
    Hello @kent_henderson
    This is a great question!  You can make a drawing of multiple configurations by copying the original drawing and simply changing the configuration.
    Right click on the drawing tab and select duplicate.
    Once the drawing is copied, right click on the views you wish to change. Select "change configuration."
    The part, part metadata and dimensions will update.  Hope this helps!
  • kent_hendersonkent_henderson Member Posts: 71 PRO
    That's perfect. Thank you. I feel dumb. I've been using Onshape for years and never noticed "Change Configuration" when I right clicked in a drawing. Thanks Mr Obvious.
