Mirror
imagineered
Member Posts: 57 ✭✭
I'm probably missing something here, but is there a method of mirroring components in an assembly?
ie with the choice of just a mirrored placement and/or creating a mirrored component?
raj_Onshape
Onshape Employees Posts: 111
At this time we do not have mirroring of components in assembly. As a workaround you can mirror the parts in part studio and insert both the original and mirrored part into the assembly4 -
imagineered
Member Posts: 57 ✭✭
thanks @ptrajkumar - bit of extra work - it'll have to work for now :-)
5
Onshape 40 seconds..
A lot of queries on this forum arise from a 'business as usual ' assumption about the purpose of Onshape assemblies.
The only "assembly mirror" facility which would make sense to me, if Onshape was being used as designed, would be a dynamic one, for positioning two elements so that they moved symmetrically about a specified plane. Say, for modelling a crowding mechanism, or a self-centering vice.
Onshape Assemblies are for adding motion, not for positioning static items
> Rant Mode OFF
As part of getting the mirror plane, selecting a linear edge for mid-plane works as well. It will make a plane that is normal to the edge that is in the middle of it. That way you didn't need to rotate to the other side to select the other face.
But as @andrew_troup pointed out I would need assembly mirror for keeping mirrored position for these lh / rh parts.
https://www.youtube.com/watch?v=JZZNGAAzQzs
Copies & creates the mirrored components all in one hit. (not just mirrored placements)
For one I'd like to have the ability to group in Part Studios. But this is another discussion.
The mirroring in an Assembly I have just found that it would be useful in the next situation: I have created a bunch of parts that are basically just mirrors of a few "master" parts in the parts studio. I then realized that later on in the design I'll have to import the structure in an assembly anyway so I would have liked all parts to be mated so I can't accidentally move them the way they are not supposed to be moved.
So I imported all in an assembly and started mating the "master" structures. All nice and dandy. Now somehow I wish the mirrored structures would somehow just inherit the mating from the original ones. Instead, I have to mate again and again every mirror, which is time consuming and inefficient.
How would you do this from a design intent pov in an time-efficient manner?
Unfortunately I do not have a solution to mirroring your mating scheme, but I hope I can make the geometry creation aspect of your mirror easier. To create mirrored geometry in an assembly you can do the following:
1. Right click on the origin of the assembly and click "Create Part Studio in context", then click the green check box. You will automatically be switched to this new Part Studio
2. Create a Plane in this new part studio that you would like to mirror across.
3. Use the mirror feature in the part studio to mirror all the parts you want across the mirror plane.
4. Click "Insert and go to assembly" at the top of the graphics area.
5. Select all the parts in the part list and press the green check box.
Hopefully this makes your life a little easier at least on the geometry creation front. If you would like to see the Assembly Mirror implemented please vote on an improvement request such as this one or similar:
https://forum.onshape.com/discussion/5763/mirror-feature-for-assembly-workflow
In the assembly, you then just Group the "new" parts with 1 of the other parts and it is fixed.
Thank you
