"Roll to here" in graphics area right mouse button (context) menu
Justin_6Justin_6 Member Posts: 2 PRO
Rolling back to a feature once the feature tree grows large one must click a feature in the graphics area then move back to the feature tree to roll back. A more efficient work flow is to add roll back options to the graphics area right click menu. For example, RMB on fillet in graphics area results in an option of "Roll above Fillet xxx".
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    @Justin_6 the graphics area can be be a number of features you pick on.  The workflow can be select in the graphics area and see what highlights.. there might be a few areas then pick the one you want to roll back to.  The graphics area is. not a 1 to 1 relationship in many cases.
