Filter instantiators to not show plans, Mate connector.
DASDAS Member Posts: 5 ✭✭
edited April 2020 in FeatureScript
Hi, I'm starting to handle FeatureScript, I wanted to know if there is a way to filter instantiators to not show plans, Mate connector.
import(path : "13fb9636d7d0307d8a5162a6", version : "efe9ea3071740725a074f15c");
export enum SeletModel
    annotation { "Name" : "Type_0" }
    Type_Z,
    annotation { "Name" : "Type_A" }
    Type_A,
    annotation { "Name" : "Type_B" }
    Type_B
annotation { "Feature Type Name" : "Instance" }
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        // Define the parameters of the feature type
        annotation { "Name" : "REAR WHEEL", }
        definition.SeletModel is SeletModel; //=========
        annotation { "Name" : "Rear_1" }
        isAngle(definition.Rear_1, ANGLE_360_BOUNDS); ///------>
        annotation { "Name" : "Stak" }
        isLength(definition.Area_1, { (millimeter) : [1e-5, 600, 1e5] } as LengthBoundSpec);
        annotation { "Name" : "Reach", "Default" : 50 }
        isLength(definition.Axis_Z, { (millimeter) : [1e-5, 600, 1e5] } as LengthBoundSpec);
        // Define the function's action
        const instantiator = newInstantiator(id + "instantiator");
        if (definition.SeletModel == SeletModel.Type_A)
            addInstance(instantiator, build, {
                        "partQuery" : qConstructionFilter(qEverything(EntityType.BODY), ConstructionObject.NO),   //???
                        "configuration" : {
                                "SeletModel" : SeletModel_conf.Type_B,
                                // "Orientation" : SeletModel_conf.[definition.SeletModel],
                                "Axis_Z" : definition.Axis_Z,
                                "Area_1" : definition.Area_1,
                                "Rotate_1" : definition.Rear_1
                        "transform" : identityTransform()
        if (definition.SeletModel == SeletModel.Type_B)
                         "partQuery" : qConstructionFilter(qEverything(EntityType.BODY), ConstructionObject.NO), // ?????
                         "configuration" : {
                                "SeletModel" : SeletModel_conf.Type_A,
          instantiate(context, instantiator);
  • DASDAS Member Posts: 5 ✭✭
    edited April 2020
    How to filter the "Plane" and lMate connector
    https://cad.onshape.com/documents/1c29fe218a63aa8e0fcdc382/w/2591152355d300f944f280c5/e/da4bdb1277ab6124ca3a093c
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,060 ✭✭✭✭✭
    @DAS
    Can you use qBodyType(..., BodyType.SOLID)
    Thanks MBartlett21
    This solves my doubt my problem
    "partQuery" : qBodyType(qEverything(EntityType.BODY), BodyType.SOLID), </code>"partQuery" : qConstructionFilter(qEverything(EntityType.BODY), ConstructionObject.NO), // ?????</pre><br><blockquote class="Quote"> <div><a rel="nofollow">MBartlett21</a> said:</div> <div>@DAS<br>Can you use <code>qBodyType(..., BodyType.SOLID)
    I leave this little example here ...
    import(path : "13fb9636d7d0307d8a5162a6", version : "a209c9a751a978707c2f3ea8");
    export enum SelecMod
        annotation { "Name" : "NOT" }
        NOTTT,
        Type_A,
        Type_B,
        annotation { "Name" : "Type_C" }
        Type_C
    export const SelecType = {
            SelecMod.Type_A : SelecModel_conf.Type_A,
            SelecMod.Type_B : SelecModel_conf.Type_B,
            SelecMod.Type_C : SelecModel_conf.Type_C
    export enum SelecFilter
        Type_A,
        Type_B,
        Type_C
    export const SelecTypeFilter = {
            SelecFilter.Type_A : qConstructionFilter(qEverything(EntityType.BODY), ConstructionObject.YES),
            SelecFilter.Type_B : qConstructionFilter(qEverything(EntityType.BODY), ConstructionObject.NO),
            SelecFilter.Type_C : qBodyType(qEverything(EntityType.BODY), BodyType.SOLID)
            // SelecTypeFilter[definition.SelecFilter]
        precondition
            annotation { "Name" : "REAR WHEEL", } //=========
            definition.SelecModel is SelecMod;
            definition.SelecFilter is SelecFilter;
            if (definition.SelecModel != SelecMod.NOTTT)
                            // include sketches, only exclude default
                            "partQuery" : SelecTypeFilter[definition.SelecFilter],
                            "configuration" : {
                                    "SelecModel" : SelecType[definition.SelecModel], //SelecModel_conf.Type_A,
                                    "Rotate_1" : definition.Rear_1,
    <br>
