Is it possible to export numbers from a FeatureScript?
timo_schmid
Member Posts: 36 EDU
Hi everyone,
I'm trying to calculate a couple of values (e.g. distances) with a FeatureScript and then export them (to a type of file such as .csv, googleSheets, .txt)
Is this possible?
Any help is appreciated!
Cheers,
Timo
Is this possible?
Cheers,
Timo
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,421No, you can only print to the FeatureScript console. You would have to copy and paste from there.Senior Director, Technical Services, EMEAI1
Do you know if it would be possible to do such a task with the API instead?
Cheers,
Timo
For more information, go to https://dev-portal.onshape.com/help, click "feature list API", and search "Feature Script Evaluation" or "Evaluate FeatureScript".
You can do this one of two ways:
