How do I update a configuration within an assembly through the API?
ethan_keller924
Member, csevp Posts: 44 PRO
in General
I would like to change the configuration of a particular part instance within an assembly without importing a new part. Is this possible with the current API? I don't see any way to do it currently...
Ethan_K
Member, Onshape Employees Posts: 57
Hi @Alexander_Mills ,
Ahh, yes. There is not currently an endpoint for updating an instance as you would like. I would also like this feature, and will hopefully get a chance to work on it soon. We've pulled a ticket for this improvement so that you'll be informed when it completes.
Cheers,
-Ethan6
Cheers,
-Ethan
Thanks in advance for your support !
