How can I use Threadcreator to thread to ends of pipe?
I am using Threadcreator to represent male threaded pipe. I have been able thread one end of the pipe but I'm not sure if the feature can be used to thread the opposite end.
You could also try using a circle pattern about the center.
That way they share the same thread handedness and length.
Yea, that one is a picky feature.
You can pattern the part and merge. Otherwise you will just need to flip the pitch and it will put the thread on the other end.
See both examples in link
