Reverse Bolt orientation
eric_schreibereric_schreiber Member Posts: 7 EDU
Can I reverse the bolt orientation with one command?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    If you edit the mate, you can change the which mate connector to use on the part (keep the one on the bolt), but you'll have to do it in 2 steps to get the nut on the other side too.
  • eric_schreibereric_schreiber Member Posts: 7 EDU
    Thank you. That makes sense.
    I have six bolts and four wheels, 24 bolts to turn in total.
    I suppose I need to make the wheels an assembly to reduce the work.
    edited May 2020
  • mahirmahir Member, Developers Posts: 1,319 ✭✭✭✭✭
    If possible assembly patterns should be utilized. Doing so will reduce the number parts that need to be mated.
