Dimensions Over Constrain Sketch By Default?
larry_haweslarry_hawes Member Posts: 478 PRO
Not sure how to ask this and I think I see what is happening but it's bugging me to no end. Sketch a rectangle, extrude. Sketch another rectangle that aligns with outer edges of previous rectangles and is constrained coincidentally at expected lines and points. Enter dimensions, cause I don't know what else to do complete the sketch, and the sketch is over constrained because it really doesn't need at least one dimension as it is already constrained coincidentally along that dimension.
Can the second rectangle be created without dimensions? Or some simple method to keep this kind of sketch from being over constrained?
http://www.youtube.com/watch?v=6stKRJmbtP4
  • steve_shubinsteve_shubin Member Posts: 1,112 ✭✭✭✭
    @larry_hawes
    After sketching the rectangle on the face of the cuboid, deselect the Centerpoint Rectangle Tool in the tool bar before entering any dimensions
    ...and then manually add dimensions? Seems just a little bit more awkward. The problem is, of course, that the one dimension that spans and snaps coincidentally to the existing rectangle (in this case the 9.5") just does not need to be there and can easily be deleted after the sketch becomes over constrained but seems awkward at best. Is this just simply the way Onshape works in this case?
    edited May 2020
    @larry_hawes
    In the above GIF, I answered your first question which is can the second rectangle be created without dimensions
    Think of a constraint as like an anchor. So if I snap (constrain) the bottom horizontal line of the second rectangle to that of the cuboid, and if I constrain the top horizontal line of the second rectangle to the top line of the cuboid, and then if I try to add a dimension between those two lines, the program is going to say no no no. The bottom horizontal line of the second rectangle and the top horizontal line are locked in place you cannot move them. If you want to move one of those lines of the second rectangle, you’re gonna have to release one of those constraints
    If you want to add a dimension from the bottom horizontal line to the top horizontal line of the second rectangle, then when you are sketching that second rectangle, don’t allow it to snap to one of those horizontal lines on the cuboid
    You can add a dimension to the width of the second rectangle and it will not go into overconstraint, as long as you don’t snap both vertical lines of the second rectangle to the vertical parts of the cuboid when sketching the second rectangle
    Thanks Steve, I could clearly see why it was being over constrained with the vertical dimension but couldn't see an order of operations that would release that vertical dimension. Your solution worked perfectly. Thanks. I sometimes sketch/build simple boxes and line up edges that were constantly being over constrained in the manner shown. I will remember this method and thank you again.
    @larry_hawes
    My pleasure. That’s good news to hear that it worked out Larry
