animate a variable
monroe_weber_shirkmonroe_weber_shirk Member Posts: 102 EDU
I'd like to create an animation by varying a configuration variable from its min to its max. Is there any way to do this?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,895
    Only manually using the mouse wheel to increment the values. You could do this from another browser window if you wanted to record the full UI.
  • monroe_weber_shirkmonroe_weber_shirk Member Posts: 102 EDU
    Thanks for the idea. The mouse increment is too large for the drawing I've created. Looks like I'll be taking screen shots...
    If you hold down the CTRL key while scrolling the increment is much smaller.
