Is it possible to make a LengthBoundSpec dependent on an input variable?
timo_schmid
Member Posts: 36 EDU
I'm searching for way to adjust the min/max input values in a FeatureScript, depending on previously selected inputs. Is that possible?
NeilCooke
Moderator, Onshape Employees Posts: 5,922
Not in the precondition - you would have to test limits in the main body of the code and throw an error.Senior Director, Technical Services, EMEA5
