[Updated] Point pattern custom feature
Some time ago @cody_armstrong put together a great Point pattern custom feature. With the passing of a couple of years and nearly 1000 FeatureScript updates, today I published V2.0. Add to your toolbar:
https://cad.onshape.com/documents/9fca78cb66a0bc83e359eb3e/v/401953fe6e5330bb77bf28ef/e/7052b96c07018ad97bbadbf9
Onshape, Inc.
Onshape, Inc.
3
Thanks for the update.
It seems that the orientation of the patterned parts is not affected by the locating points or MCs (the patterned bodies maintain their orientation). I'd like to be able to drive the orientation of the resulting patterned bodies with the orientation of the target Mate Connectors.
Do you think that would be possible?
Yes that should be doable. I will keep in mind for V2.1!
Onshape, Inc.
You can! You just have to make sure that the custom feature toolbar isn't in a dropdown when you are wanting to move a FeatureScript out of it (I generally have to zoom out to ~66% to get it out of a dropdown)
Most of the actual code was replaced with the more recent common code that drives our other pattern features. Face and Feature pattern types are also supported now.
Onshape, Inc.
Also, @MBartlett21I had to zoom out to 25%
This works beautifully!
Except when using a derived sketch. It does work when slecting individual points from the deived sketch . But given the amount of points I'm not doing that. And the point pattern does work using the original sketch in the original studio. Any thoughts?
