Split surfaces won't separate in the feature tree
svenolov_nystromsvenolov_nystrom OS Professional Posts: 85 PRO
edited May 2020 in Community Support
Is there any way to make a boolean with two faces in onshape
I have a sweep along a split edge it is ok
I can thicken the red face and the blue surface and make boolean but the joint is not nice
I have this problem making a corona face mask
sven
  • lanalana Onshape Employees Posts: 761 image
    Change Split type to Part
    It is confusing here, but Part means "Part or Surface" in this dialog
  • svenolov_nystromsvenolov_nystrom OS Professional Posts: 85 PRO
    Confusing is an understatement but thanks I am on the track .
