How do i create a lip and groove joint?
anna_forbes_jones468
Member Posts: 10 EDU
Hi,
I am trying to get the two halves to join together using a lip and groove joint. I know how to do it on Solidworks can anyone help me out with doing it in OnShape?
Many thanks!
https://cad.onshape.com/documents/7f4fee13278152aa55393279/w/432d8d8654abad8d0c3363a5/e/cfc65dfa247d061d4633cee2
Many thanks!
steve_shubin
Member Posts: 1,118 ✭✭✭✭
@anna_forbes_jones4683 Steps —
1) In a sketch, use the USE tool to select all the inner edges of Part 2
2) Then use THIN FEATURE that’s part of a custom Extrude FeatureScript to extrude that sketch
3) Then BOOLEAN SUBTRACT Part 2 from Part 1
The 3 GIFs below cover the 3 Steps above
5
I think @steve_shubin used the Feature script 'Thin-Feature Extrude' See this help for adding Feature script to your tool bar.
Alternatively, you could use the standard Extrude by following Steve's instructions except add an offset curve to the sketch to create the enclosed region of the lip.
Anna, @bruce_williams has given excellent direction on location & install procedure of THIN FEATURE, and a nice tip on using offset on the sketch
Thanks Bruce !
And myself, I’m always interested to see alternative ways that people do things. Thanks @mahir
