Round to closest list value?
Evan_ReeseEvan_Reese Member Posts: 2,066 PRO
edited May 2020 in Using Onshape
Does anyone know of a way that I can take a number and round it to the nearest value in a predetermined list (maybe an array)? For example:
if my list is [1,4,8,11,12]
1.9 rounds to 1
9.3 rounds to 8
9.5 rounds to 11
11.6 rounds to 12
There's got to be a name for such a thing.
Evan Reese / Principal and Industrial Designer with Ovyl
Website: ovyl.io
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,902 PRO
    There are a few rounding funcitons
    ceil() rounds up to  nearest whole number
    floor() rounds down to nearest whole number
    round() rounds to nearest up or down to nearest whole number
    roundToPrecision() will round with decimals
    var listStart = [1.9859,9.23,9.2525,11.652,0.654110111];
            var listFloor = [];
            var listCeil = [];
            var listRound = [];
            var listRoundToPrecision = [];
            for (var item in listStart)
                listFloor = append(listFloor, floor(item));
                listCeil = append(listCeil, ceil(item));
                listRound = append(listRound, round(item));
                listRoundToPrecision = append(listRoundToPrecision, roundToPrecision(item, 2));
            println("Original List: " ~ listStart);
            println("Rounded List Down: " ~ listFloor);
            println("Rounded List Up: " ~ listCeil);
            println("Rounded List Nearest: " ~ listRound);
            println("Rounded List Nearest (2 place decimal): " ~ listRoundToPrecision);
    // result \\
    Original List: [ 1.9859 , 9.23 , 9.2525 , 11.652 , 0.654110111 ]
    Rounded List Down: [ 1 , 9 , 9 , 11 , 0 ]
    Rounded List Up: [ 2 , 10 , 10 , 12 , 1 ]
    Rounded List Nearest: [ 2 , 9 , 9 , 12 , 1 ]
    Rounded List Nearest (2 place decimal): [ 1.99 , 9.23 , 9.25 , 11.65 , 0.65 ]
    edited May 2020
    I have a function maxItem() which returns a max value of the list based on some other estimation function:
    <pre class="CodeBlock"><code>function maxItem(container is array, estimationFunction is function)<br>{<br>&nbsp;&nbsp;&nbsp; var max = container[0];<br>&nbsp;&nbsp;&nbsp; for (var item in container)<br>&nbsp;&nbsp;&nbsp; {<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; if (estimationFunction(item) > estimationFunction(max))<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; max = item;<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }<br>&nbsp;&nbsp;&nbsp; }<br>&nbsp;&nbsp;&nbsp; return max;<br>}
    say we have a value "value" and estimation function may be:
    const estFunction = function(x){return -abs(x - value)};
    then you just do this:
    const roundedItem = maxItem(roundedArr, estFunction);
    ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,178
    If your array is small, Konstantin's method works fine.  If you have a large array, the efficient method for solving this problem is binary search: https://en.wikipedia.org/wiki/Binary_search_algorithm#Procedure_for_finding_the_leftmost_element (use that procedure and then pick the closer one of A[L] and A[L-1])
    Thanks for all the info everyone!
    Website: ovyl.io
