Fairly new here, need help with mates and overdefined assemblies
riccardo_ingrosso
Member Posts: 9 ✭
Hi there. This is my first post so I hope I'm not breaking any rules and I apologise if I am asking a stupid question.
I am trying to design a mechanism with two identical arms on either side of an assembly. There are several mates of different types and everything works fine until I come to the final two mates. I need two revolute mates in exactly the same spot, one on the top of each arm. With one suppressed, all is good but with both active the assembly is over defined.
Can someone help me to understand why this is and how to fix it?
That means, if I'm mating a bolt to hole, I used to think about mating the bolt and hole to be concentric, then mating the head of the bolt to be planar with with the top of the hole. With Onshape, all off that can be specified with a single "fixed" mate and the appropriate mate connectors. So, now I'm thinking about how I want the bolt part to be fixed relative to the part with the hole. Then, the selection of my mate connectors define the geometric relationship.
Apologies if you figured all of this out already, but I wanted to pass along something that I didn't realize right away. Perhaps it may help ensure things aren't over-constrained if you're going back to the drawing board with your assembly.
Thanks again.
To share the Doc URL, is it a simple copy and paste of the address bar? Like this?
https://cad.onshape.com/documents/30deccb5aaa93639cd708721/w/844cce8d07a1b51ac503c020/e/421d5ede1ddb0a1ab47ecd58<br>This is the next version. Is there a quick and easy way to duplicate the scissor mechanism from where it is to the opposite side of the hatch?
Thanks in advance.
https://cad.onshape.com/documents/cd7bf61e2d5385230c72ee7c/w/3bf68953f7ce394fbac5c6d1/e/9418aeaedad65a596156eca2
No mirror as yet, you'll have to replicate on the other side - you can however copy and paste the 2 linkages and they will at least retain the revolute between them.
