Boolean Help Enquiry
thomas_veryard
Member Posts: 2 ✭
Hey there,
I'm trying to create a simple join connecting the lower spindles of this chair to the rear and front uprights using the boolean tool and derived parts but am having some trouble. I have managed to use the boolean tool on the rear uprights to create a hole for the spindle (shown by the part exploded view below) however when I try to do the same in the front upright part studio it tells me I can't because of cyclical references.
I managed to join the seat spindle manually through exact measurements however haven't been able to accurately join the lower spindles this way. Is there a way in which I can use a boolean remove again the same way for the front uprights?
(The bottom image shows where the lower spindles need to be inserted into the front uprights)
I'm looking to
I'm looking to
Can you share the link to your document?
