i would like to create a pattern on a resolved model - grenade
Hi All,
i have created so far a version 1 of an airsoft grenade.
i am missing the lines that are coming from the top to the bottom(blue ones), I created the lines from right to left.
how can I do it in order to make it look like a real grenade?
Can you share the link to your document?
https://cad.onshape.com/documents/54a403ce06a3be86e067dbbc/w/34c535a56e8a9efe82fd627c/e/5a510be0573afe1a32e03383
My best guess would be that the small external fillets are keeping the shell from working. OS can't handle the small radii going to zero as the surfaces are offset during a shell command. To fix this, add the shell prior to the fillet.
