Create a ridge on existing face
Hi gang! Everytime I ask a question here I learn so much, so I'm going to keep going with that trend (until someone tells me to stop, or until I can answer some questions, myself!)
I have an opening in a solid that into which another part can fit. In order to make a more snug connection, I'd like to add a very small ridge or lip all around that opening. This lip could be rounded or angular (preferably rounded). I could conceivably use a circular profile and run it around a projected drawing of the edge to get the lip, but I'm wondering if there's another way, similar to the way Thicken might work.
Thicken would affect the entire face, but I'm looking for just a small portion of that face to be thickened as it were (and then filletted to make a rounder shape).
The "edge" I'm looking to "thicken" or create a lip on here is the inside edge of the chamfer all around the opening.
Any creative ideas welcomed! I'm just here to learn and loving every minute of it.
Be well and thanks in advance!
mahir Member, Developers Posts: 1,316 ✭✭✭✭✭
@tom_auger, you can do the same thing natively without featurescript, but it would take a few extra steps.- Create a plane on your desired edges
- Create a sketch and convert those edges
- Extrude the sketch as a surface
- Thicken the surface to create a thin-extrude
5
I extruded this up higher just so you can easily see how the tool works. You don’t have to extrude up as high. And you don’t have to make it as thick.
From here, you can select the top face of what you extruded up using the thin feature tool, and then put a fillet on it
Here is where you will find the Extrude FeatureScript used to do this
d4ef208f8075c2efd086c6be
Thanks,
Tom
If I'm not mistaken, the FS just automates this process.Yeah you’re right. It is not one of the tools that comes with the program when you first start using it.
I don’t know where you stand on this, but I had a friend that was adverse to using anything other than the native tools on a CAD package we both used to use way back when.
Obviously a lot of us like answering questions and we all learn together. So keep em coming!
Here is a different read I had on your OP and a bit of different methods (see document here). I like using mate connectors for sketch. Here you can see i shifted MC down a bit off the corner of chamfer. Then make a sketch with Use of chamfer corner, extrude surface as @mahir suggested, then thicken with add turned on and finally fillet.
That all said, I think your first inclination of using Sweep was the right one, but you asked for variety...
THIN FEATURE will allow you to extrude UPWARD or INWARD
Good read on OP by @bruce_williams
Never crossed my simple mind
It's a beautiful FeatureScript! I'm certainly not adverse to FS - been learning it myself. However, first I want to understand what is natively capable to increase my comprehension not just of the software, but also the kind of thinking you need to have to be able to successfully model anything – and for that I think it's best to understand what is natively possible first.
Thanks so much for that time-saving script!
So, your FS are just like any other native feature.
Please, don't try this with other CAD system ;-)
