Why Feature Script opExtrude REMOVE not working and making a NEW part?
shimon_shmulmanshimon_shmulman Member Posts: 5
edited June 2020 in Community Support
Hello,
I am trying to shorten the cylinder by opExtrude with the following code:
FeatureScript 1301;
import(path : "onshape/std/geometry.fs", version : "1301.0");
annotation { "Feature Type Name" : "Face 03" }
export const face03 = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "Face", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1 }
        definition.prop_face is Query;
        opExtrude(context, id + "extrude1", {
                    "operationType" : NewBodyOperationType.REMOVE,
                    "entities" : definition.prop_face,
                    "direction" : evPlane(context, { "face" : definition.prop_face }).normal * -1,
                    "endBound" : BoundingType.BLIND,
                    "endDepth" : 200 * millimeter
For some reason NewBodyOperationType.REMOVE tag is not working and a new part is generated.
Please help, what can be done?
Shimon
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,987 image
    operationType is not a parameter for opExtrude. You will need to do an opBoolean to remove the body created by your opExtrude. This is the preferred method.
    The extrude function includes opBoolean and so operationType is valid for that.
  • shimon_shmulmanshimon_shmulman Member Posts: 5
    Neil,
    Thank you for your answer. I tried to use extrude, but it has no effect on the part.
    I must be doing something wrong.
    FeatureScript 1301;
        precondition
            extrude(context, id + "extrude1", {
                        "defaultScope" : true,
                        "depth" : 200 * millimeter
    Neil,
    Thanks for your help!
    Shimon
    edited June 2020
    Just want to share with the community the working code for this issue:
    <b>FeatureScript 1301;</b><br><b>import(path : "onshape/std/geometry.fs", version : "1301.0");</b><br><b>annotation { "Feature Type Name" : "Face 03" }</b><br><b>export const face03 = defineFeature(function(context is Context, id is Id, definition is map)</b><br><b>&nbsp; &nbsp; precondition</b><br><b>&nbsp; &nbsp; {</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp; annotation { "Name" : "Face", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1 }</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp; definition.prop_face is Query;</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp; annotation { "Name" : "Solid", "Filter" : EntityType.BODY, "MaxNumberOfPicks" : 1 }</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp; definition.prop_body is Query;</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp;&nbsp;</b><br><b>&nbsp; &nbsp; }</b><br><b>&nbsp; &nbsp; {</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp; opExtrude(context, id + "extrude1", {&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; "operationType" : NewBodyOperationType.REMOVE,&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;&nbsp;</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; "entities" : definition.prop_face,</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; "direction" : evPlane(context, { "face" : definition.prop_face }).normal * -1,</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; "endBound" : BoundingType.BLIND,</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; "endDepth" : 200 * millimeter</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; });</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp; opBoolean(context, id + "boolean1", {</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; "tools" : qBodyType(qCreatedBy(id + "extrude1", EntityType.BODY), BodyType.SOLID),</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; "targets" : definition.prop_body,</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; "operationType" : BooleanOperationType.SUBTRACTION</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp; });</b><br><b>&nbsp; &nbsp; &nbsp; &nbsp;&nbsp;</b><br><b>&nbsp; &nbsp; });</b>
    FYI @shimon_shmulman
    You can hit the "code" formatting button:
    And then paste code from your feature studio into the yellow box that shows up.
    example
    Jake,
    I did hit the code format, but then only the first line was visible.
    Is it supposed to work this way?
    In addition, I still do not understand what was wrong with my extrude function.
    Shimon
