Upload filse to my computer
mark_wilson
Member Posts: 2 ✭✭
Its easy enough to export an stl file and to import most common cad files. Is it possible to export an iges step or parasolid back onto my computer so that I can run my CAM software and machine the part.
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
@mark_wilson if you right click on the tab and select export you can select the format to create.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5
Thanks for that, I looked everywhere for that and couldn't find it. As you pointed out, its on the tab.
