Upvoting improvement request
Is it possible to search through the existing improvement requests, and if the request I want to add already exists, upvote that spcific request? Or should I always create my own improvement request?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,931 image
    Please search first otherwise the vote for a feature may become “diluted”. Go to the improvement request category then use the search bar at the top.
    Although you are a Pro customer so you can also send your request via a support ticket and the support team will add your request to the list if it doesn’t already exist.
  • Jochem_van_DeelenJochem_van_Deelen Member Posts: 6 PRO
    Thanks Neil. That's exactly how I hoped it would work.
