Creating a Partial Thread
ethan_1
Member Posts: 17 EDU
Has anyone had any luck creating a partial thread. Meaning I don't want the helix to go the entire way down the cylinder, say only and inch down. See picture attached.
Hi @ethan_1 as @cadmando suggest create two cylinders the second one extrude it as a new part so when you select the helix command it recognizes one of the cylinders, after finishing you can use the boolean command to convert everything into one part. (See image below)
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions5
Create 2 Cylinders, one for the threaded part and one for the Black Part, Sketch the second on the end of the first.
Hope this helps, happy OS'ing
Graham
See 'Partial Thread' Doc in the Public Doc's
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions5 -
Hi Nav
Well done with the method, I am not sure how to take a snapshot of the screen and post it to the forum, anyway I only gave the basic information, left it for @ethan to work through it alone, I learn thing better that way.
Are there instructions any ware which explains how to take snapshots and Publish to the forum, I must learn how to do this for the future.
Graham
Did a search on snapshot and found a good description of the method by 3Dcad, so will give it a go.
Hi @cadmando if you are on a MAC you can take screenshots using :
- Press Command (⌘)-Shift-3. (whole screen) / (⌘)-Shift-4 (Part of your screen)
- Find the screenshot as a .png file on your desktop.
To upload an image to the forum see image below:
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions0 - Press Command (⌘)-Shift-3. (whole screen) / (⌘)-Shift-4 (Part of your screen)
Thanks Nav, I use Windows have used the method by 3Dcad, will try your way in Paint to crop out unwanted area
Graham
The "Snipping Tool" is indeed a great feature (introduced in Windows 7) - but one tip for serious use:
If you plan to use the commenting features mentioned by @3dcad , it pays to save the snip first, because there is no "Undo" within the tool. If I have several edits (particularly freehanding with the mouse) and I don't want it to look amateurish, I save again after each successful addition.
This is a perplexing omission. It's not just the menu command they've omitted, Control-Z doesn't work, either. Microsoft - late to the table and forgetting the salt... sheesh!.
No 3Dcad, I didn't know about the snipping tool, I have just found it and given it a go, looks a great tool for creating a quick snapshot, I will try it next time, THANKS for the tip
Graham
If you use CMD+SHIFT+CTRL+4 the image will be on the Clipboard rather than fetching a file. For further mods you can use the Preview app + paste then use the markup tools to annotate etc.nav said:Hi @cadmando if you are on a MAC you can take screenshots using :- Press Command (⌘)-Shift-3. (whole screen) / (⌘)-Shift-4 (Part of your screen)
I upload screenshots by dragging them from my folder into the text area here.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com0
@jakeramsley ( @lougallo ) It would be nice if screenshots could be inserted from clipboard without saving them..
//rami1 -
viru,your method is very good , I used it for creating partial thread in my models just now,thanks for sharing! But I also hope we can define the values of "count" and "pitch" at the same time directly, namely creat a partial thread directly,maybe it is more convenient!
1 -
@shanshan: I agree: this is definitely a workaround to accommodate a helix feature which is not yet fully implemented.
It is not desirable to have a curve which extends into "free" space, because it does not reflect design intent.
