Part Scaling in Onshape
jeffrey_yujeffrey_yu Member Posts: 2
Hi all,
I am trying to scale a finished part, does anyone know if Onshape does scaling?
Thanks,
Jeff
  • grochinogrochino Moderator, Onshape Employees, User Group Leader Posts: 44
    You can choose Scale uniformly as the transform type with the Transform tool.
  • richie_trentrichie_trent Member Posts: 4 PRO
    GREAT TIP!!
    This just saved me so much time.  I actually needed to scale a sketch, but used this scale part function, then just created a sketch from the part.
    Thanks!
  • paul_elliott363paul_elliott363 Member Posts: 7
    I have no problem defining the entities, of which there are 4 in my example, but, what on earth will be the point? I can't make anything work?
  • lanalana Onshape Employees Posts: 726
    @paul_elliott363
    Any point selection should work - that is the point that does not move in scaling. It is only important if you want to control end position of the part.
  • varocketryvarocketry Member Posts: 6
    I have a cylinrical part that is 60 mm in length.  I want to change that to 40mm.  But I don't want all the other dimensions to change.  How do I accomplish this?
  • glen_dewsburyglen_dewsbury Member Posts: 986 ✭✭✭✭
    edited September 2023
    Change the original sketch or extrude. If your looking to keep both sizes then look into part configurations. I you're just not sure about the height when starting out, a configuration variable can be used that is easy to change.
    https://cad.onshape.com/documents/a9e269b89c55888131122ba3/w/441fc8bec72aef2b5be3ed5d/e/2c13dd92de1ec66a4a97229c
  • tim_wheelertim_wheeler Member Posts: 19 PRO
    edited March 2024
    Or use Move Face, switch to translate from offset and click on the face.  Determine direction and enter the dimensional change.
